Can't change nameservers to InfinityFree
When you try to point your domain to InfinityFree’s nameservers (ns1.infinityfree.com and ns2.infinityfree.com), your registrar might refuse the change with error messages like:
DNS Query Refused
ERROR: Answer must be authoritative
The name server is not responsible for this domain
Domain is not activated in the nameservers
What should I do?
You have two main options to solve this problem:
Option 1: Use CNAME verification instead
Instead of changing nameservers, you can verify your domain ownership by adding a CNAME record to your current DNS settings. This is often the easiest solution.
You can find step-by-step instructions for CNAME verification here:
Option 2: Switch to a different registrar
Some domain registrars are more flexible about nameserver changes than others. If your current registrar won’t let you update the nameservers, you can transfer your domain to one that doesn’t enforce these strict checks.
For example, Spaceship is a registrar that works well with InfinityFree and doesn’t block nameserver changes for this reason.
Why does this happen?
This is a chicken-and-egg problem: the system wants to see DNS records before allowing the nameserver change, but we can’t create the DNS records until your domain is added to your hosting account.
The validation can happen at two levels. Registry-level validation is enforced by the organization that manages the domain extension (like .de or .com.br) and applies regardless of which registrar you use. Registrar-level validation is enforced by your specific domain provider and varies between companies, though this is becoming less common.
When your registrar or registry checks our nameservers for your domain’s DNS records, they don’t find any because we only create them after you successfully add the domain to your InfinityFree account. This causes the validation to fail and prevents the nameserver change.
Which domains are affected?
Registry-level validation: These domain extensions have strict rules built into the system that cannot be bypassed:
  • .com.br
  • .de
  • .dk
  • .hu
  • .it
For these extensions, CNAME verification is your only option.
Registrar-level validation: This can potentially happen with any domain extension (.com, .net, .org, etc.) depending on your registrar’s policies, but it’s becoming less common.
What won’t work
Waiting: The error won’t resolve on its own since we need your domain added to your account before we can create the DNS records.
Summary
If you can’t change your nameservers to InfinityFree’s servers, use the CNAME verification method instead. It’s usually faster and easier than trying to work around registrar or registry restrictions.
Rejected search registro.br
DNS Zone for .de
Trouble adding custom domain
I'm not able to configure ns2.epizy.com
Really big problem using InfnityFree DNS on . IT domain!
Erro ao configurar dominio .com.br
Nameservser setup
Error for adding nameserver to my domain
Issue with Connecting Aruba Domain to InfinityFree Hosting: Invalid NameServer Error
Nameserver error
Website Server-iP not found
Erro de pesquisa (.com.br)
What happened to Name Servers?
Internet.bs nameserver configuration
Domain with international name
Host Website with .de Google Domain for free
IP address of ns1.epizy.com and ns2.epizy.com
The specified name server is not responsible for this domain
Configuração dns
Unable to set nameserver for .de domain
Error adding name servers
Problema configurazione DNS
InfinityFree nameservers blocking DNS pointing
Nameserver for .de Domain
.co.za domain
.co.za domain
.co.za domain
Problemi di connessione del dominio
Nameservers error
Cant set up a connection between my Domain and Nameservers
Why can't I add my domain?
DNS not recognize
Hostgator Domain Name for InfinityFree Hosting (Please help me on this issue)
Created new account/subdomain, set up a redirect - pointing to the subdomain via CNAME fails
Problem with add domain
I can't change DNS
Dns
Domain is still not pointing to ns1.epizy.com and ns2.epizy.com
I can't direct DNS
Cloudfare DNS update with Infinityfree server names
Problem DNS migration
Google Domain Registry denied DNS servers
Question about the changes in the Domain Name System stemming from australia
This site cant be reached
Problem with Google Domain
DNS not work
How to get the full values of the DNS record
Problems pointing domain to infinityfree
Hosting
DNS query refused
Domain Not pointing to nameserver?
Google domain
Do I face certificate (SSL issues) if I use a domain from GoDaddy?
DNS not correct work
Host nameserver connection failed
Nameservers won´t connect to .de domain
Can’t connect my domain to InfinityFree
Search refused nameservers
Alter DNS for TXT
Nameservers
Problem Adding Domain to Hosting Account
Registro.br vs Infinity Free - DNS issue
Unable to point my domain to epizy nameservers
I have problem in adding new domain
Can't add IF nameserver
Dns
Step 3: Set up DNS Records for still in not ready
"Search refused" issue on epizy.com nameservers
When i try to change the name servers error message? We couldn't get domains SOA record
Impossible to change nameserver
Point dns w/o nameservers
Host domain without point nameservers
Domain activation
Domain Pointing
Domain Pointing
Domain Pointing
Domain Pointing
Setting up dns
Setting up dns
Gerenciamento dns
Create a new account with dynadot domain
Nameserver not works
DNS query refused
Add domain
Name Servers Pointing Issue for Domain but!!!
I am not able to set the nameserver for my addon domain - SOA record not returned
.it domain nameservers check test error
How does this make sense?
DNS "Research Refusal"
Account
Connecting domain to site
Can't point domain to nameservers
Can't create acount due to nameserver issues
Which are the IP adress for this name server: ns1.infinityfree.com , ns2.infinityfree.com?
Error after 3 days of trying to add domain
Can't configure DNS for a .br domain
Adding domain issue
Error DNS
Nameserver nsX.infinityfree.com does not work with .de
Nameserver doesnt work
How do I change the nameservers of my .de domain name?
Nameservers
Nameserver failed for 5 days
Changing Nameserver to infinityfree
Help! I'm trying to change my domain name and having problems with DNS Status
DNS configuration assistance for .it domains
Point domain
Zone verification failed. The name server rejects the zone
How to display another name than infinityFree on google search?
Cant Connect Nameservers
Can't point InfinityFree DNS
Problem Porint Custom Domain Across to ns2.epizy.com
Error Adding Domain
DNS refused
DNS refused
Transfer my hostinger domain to Infinityfree
I can't add my Hostinger domain to Infinity Free hosting
How to transfer domain
Nmaserver Error
Website not showing after 72 hours on custom domain
Nameservers error on domain registrar
Cant add nameservers
Changing DNS on my website
A post was merged into an existing topic: How to add your domain with CNAME verification
