Connecting to MySQL from an external application
Sometimes, you may want to connect to your MySQL database on your free hosting account using external software, like a desktop database manager (like MySQL Workbench) or an external program you wrote yourself (like an Android or iOS app).
You cannot connect to a free hosting MySQL database from outside your hosting account.
You can only interact with your free hosting database through PHP scripts uploaded to your free hosting account, or through our phpMyAdmin installation.
The ability to connect to a database is exclusive to premium hosting. On premium hosting, you get cPanel including the Remote MySQL section, where you can grant external systems access to your databases.
Database Connection to Website
I Cannot Connect My Database For Login Forms
Not able to Connect to MYSQL Server
How do i find database ip adress?
Can't connect to mysql server
I can't link my database
Python cannot connect to InfinityFree Mysql
Unable to connect to SQL vi PHP
Need help connecting MYSQL and php
How to connect to mysql database with DBeaver
PhpMyAdmin with my code
I cannot connect to MySQL server, but I still can open it via PHP Admin
Database Connection Issue node js
Detalhes do banco de dados nao funciona no meu app
Issue with Remote MySQL Database Connection
Php_network_getaddresses: getaddrinfo for sql108.infinityfree.com failed: Name or service not known
PHP Connection string C#
Problems connecting to the database
Can i use infinityfree for my game database?
Connecting MySQL to infinityfree
Host does not exist when calling it using php
Error connecting PhpMyAdmin server to bot in python
Website database dont work
No such host is known
What is the minimum account that allows access to the mysql database with an external application?
Unable to Resolve MySQL Server Hostname sql204.infinityfree.com
Can't connect to new database
Workbench
MySQL hostname still not online after a week
Database Connection Error
Form data fetch problem
Unity MySQL error
I'm experiencing issues connecting to my MySQL database on port 3306. I've tried using Telne
Problem phpmyadmin
Como puedo probar el hos de sql de infinity? al poner http://sql207.infinityfree.com/ no funciona y
Unable to Connect to MySQL Host (sql305.infinityfree.com or sql305.epizy.com)
Hi I have a sql problem
Connecting to backend using unity
Cannot access phpMyAdmin
Connection Issue to Free MySQL Database - Host Unavailable
Myql application not working
Is there any option to access infinityfree database in android app using API or any other way
Can I Open DB Using MySQL Workbench?
Mysql Databasses
Still no success with db and json
How to connect my database with MySQL-Front?
I have a problem with connect to mysql database
Remote controlled car through infinityfree
Using infinity free cpanel PhpMyAdmin in other websites
Error creating a MYSQL function
Spatial Database Connection
How do I connect C# with MySQL
Database connection with node js using express
How to see your database port
No route to host
Help me mysql
Can't connect to FTP and MYSQL even if website is ready
Cannot access MySQL database after creation?
Can't connect to database
Can´t connect to database
How to connect MySQL database with HTML form
Can't connect to server on 'sql212.epizy.com' (10060)uery
Can I connect to IFastNet database with a Python script located on browser?
Mysql client not workin
Uploading data to sql database using nodeMCU through php file
What to put in database port
Access to fetch has been blocked by CORS policy
MySQL Server not accepting connections
Security Scan Spring4Shell
Can Other servers interact with Php hosted here?
How to connect infinity free mysql with prisma?
Site requires Javascript to work
Problem connecting infinityfree with marid
SQLSTATE[HY000] [1044] Access denied on remote server (user seems correctly configured)
Form's script can't conect to database
MySQL hostname sql206.infinityfree.com does not resolve — error 2002
Issue connecting my APP into the Database
API for MySQL Database
Hosting SQL DB ONLY on infinityfree
Cant conenc to mysqli db
Using Mysql database for connecting to java
Error: getaddrinfo ENOTFOUND sql303.infinityfree.com
Assistance Required for MySQL Database Connection Issue
Remote Mysql
Cross-Account MySQL, is it possible?
How to send data from Vb application to remote Myqls databse in infiinity
