What is an Entry Process and what does the limit mean
One of the limits InfinityFree enforces is the Entry Process Failures limit, also abbreviated to Entry Process limit or EP limit. This article explains what an entry process is, what the limit means and how you can control it.
What is an entry process?
Every time a request to a URL on your website is made, a new program is started to retrieve the content of that URL. This process then executes your code, sends the response to the visitor, and finally quits.
Note that one entry process is created for every request, not every PHP file. So if your code includes multiple PHP files, these still count as one entry process.
What is an entry process failure?
In order to prevent a short spike of traffic from causing problems to the server, there is a limit on how many entry processes can exist at a time for your account. If your account is at this limit, then no more processes can be created for your account and visitors will see an error page. These failed requests are counted as “entry process failures”.
So entry process failures are evidence of bursts of traffic which (temporarily) overwhelm your hosting account.
How extreme these bursts are can be derived from the hits limit. Is your entry process usage high but your hits usage low? That means the bursts were more extreme. Is your entry process usage high and your hits usage too? Then the bursts were longer but less intense.
How do I reduce my entry process usage?
Here are some recommendations which may help to reduce your entry process limits.
  • Ensure static files (like HTML or CSS files) don’t have the .php file extension. All requests to files with the .php extension generate entry processes, even if there is no actual PHP code in the file.
  • Reduce usage of AJAX and other background requests. If your website has code that constantly refreshes the page in the background (to check for changes or new messages), this can easily cause high entry process usage with few visitors.
How do I increase my entry process allocation?
The entry process allocation on free hosting cannot be increased upon request. We treat all accounts equally, and will not give people unfair benefits just because they ask for it.
If your entry process usage is still too high after following the recommendations here (or you are having trouble applying the tips to your website), please consider upgrading your account to premium hosting.
On premium hosting the entry process allocation is much higher than on free hosting. And your website will only be affected when you’re using too much processes, and won’t be suspended for a day if you hit the limit too much.
Entry Process limit hit
Constantly Temporarily Suspended because of Entry Process Limits
Entry process limit reached
Suspended when viewing my art gallery
My account have shown that it hits Entry Process limits
Why did I reach my limit?
This mail is to inform you that your site... utilised over 50% of its daily resource limits
I suspended myself again
Differences HTML to PHP
My account has been Suspended For hitting daily entry limit
My website has been suppend
Redirect email from zoho to my infinityfree
Account Susppend 24 hours
Don't see my images
Suspended website because of entry process limit
About my store trafic!
Entry Process limits always blocking
WordPress doesn't work
EP limit being reached immeditely
PHP resource warning
Website don't display some of the image files
Site is still suspended
Your account is Temporarily Suspended
My website is offline again!
Temporary Suspended Account
How to find the php file causing Entry Process Limits
Hello my web site is suspended, but the website is workinge like visit card, and i have not so many
A attack?
Wordpress post editor missing tags & categories
Repetitive Account Suspension
How many PHP requests can InfinityFree handle?
Nameless MC
'ep overuse' issue
Daily Entry Process Limit Issue for psbdx.rf.gd
Site temporarily suspended due to entry process limit
Entry Process Suspension
Account Suspension Inquiry
Resource Limit Reached Error Despite Low
Some Questions
Error accessing control panel
My account Got Suspended Why?
Account suspention for no reason
Account hitting 50% process entry limit
.htaccess file disappears from htdocs folder after editing
CPU limits
Domain suspended for reaching server limits
Resource blocking across two domains — active account and low daily usage
Addressing Entry Process limits
Finding Which Domain hit the Entry Process limits?
Website still shows resource limit error although account is Active
How can I reduce repeated Entry Process failures on my WordPress site?
PHP files blocked with “used all available resources” but usage is near zero
Elementor editor returns 508 Loop Detected errors
Entry Process suspension on taxinme.com - free job site for accountants, asking for help and options
Account temporary suspendet
Cannot access wordpress admin
Website Suspended
Question regarding how many times webpage can be opened
posts are not displaying featured images
Maximum volume of AJAX requests allowed
Account is Temporarily Suspended
Error - Entry Process Limits
Possible bot attacks - Entry Process limits
EP Suspension
A post was split to a new topic: Entry Process Suspension
It gives more information about my problem. Thank you.
