(http://golddesign.rf.gd/ )
I added php_value upload_max_filesize 512M in .htacess but it doesn’t work. then I also added it to the wp config but it still doesn’t work, no errors whatsoever.
Max file size on free hosting is 10mb.
Upgrade to premium hosting if you need more
On all InfinityFree servers is a file size limit of 10 MB. It’s important to note that this is a file size limit and not an upload limit.
The difference is subtle, but important. An upload limit could be set through PHP settings, but this limit is enforced on the file system level. No PHP configuration can override this limit and it applies to files uploaded through FTP or the file manager as well.
Can the limit be increased?
No. The size limit is fixed and cannot be increased in any way. 10 M…
The following article may help:
InfinityFree has a file size limit of 10 MB on all servers. You cannot upload files larger than 10 MB.
Installing large scripts
A particular software package may be larger than 10 MB in size. Because of this limit, you cannot upload the archive directly and have it extracted on the server. However, you can easily upload the contents manually.
To do so, you will first need a good FTP file manager for your desktop and setup an FTP connection. See the how to upload files with FTP article for more…
system
Closed
May 8, 2023, 9:29am
4
