The certificate status is Issued, and I’ve used the automatic installation feature. However, Step 5, Verify Installation, continues to show Not Found.
Chrome reports NET::ERR_CERT_AUTHORITY_INVALID for www.geraldmagallanes-port.online. The certificate viewer shows an unidentified certificate rather than a valid certificate for my domain.
Two things would help me narrow this down. First, what does an SSL checker report for both geraldmagallanes-port.online and www.geraldmagallanes-port.online? I’m after the certificate’s subject and issuer, and whether the two hostnames differ. Second, does the SSL/TLS section of your control panel show a certificate uploaded for the domain?
I’m asking because Chrome’s NET::ERR_CERT_AUTHORITY_INVALID on its own doesn’t say which certificate your browser received. The “unidentified certificate” you describe could be a self-signed placeholder, or it could be a Let’s Encrypt certificate that hasn’t taken effect yet. A checker gives a clear answer that doesn’t depend on browser caching.
Your setup matches what the guide describes. The certificate covers both the base domain and www, and with third-party nameservers the _acme-challenge CNAME goes at your DNS provider. Your A record also matches the website IP on your account. The install guide says it can take a few minutes for an installed certificate to take effect. It also says Chrome can remember a site’s old certificate for a few hours.
Here are the guides:
Two other topics describe the same symptoms: a certificate marked Issued, automatic install reported as successful, “Not Found” at the verify step, and a self-signed certificate still being served. Neither shows a fix. This might be the same thing, but I can’t tell until I see what the checker returns.
If the checker shows a self-signed certificate even though the install succeeded, that’s something a person on our staff would need to look at. You can’t fix it from your side.
It looks like something went wrong during the certificate installation. I clicked the install button again a few hours ago, and now it seems to work. I don’t know what went wrong before.
