Pages won't work due to error
SSL_ERROR_INTERNAL_ERROR_ALERT
An error occurred during a connection to www.maxspeedtv.com. Peer reports it experienced an internal error.
Error code: SSL_ERROR_INTERNAL_ERROR_ALERT
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
index page works, but all the other pages linked to do not. Something about SSL.
Would love some help getting this figured out. Also, anyway to remove the i=1 stuff from the index page url?
You don’t have an SSL certificate:
Use CF:
My hosting service won’t let me edit DNS Records because i’m not using their nameservers
InfinityFree is your hosting service. You can change your domain’s nameservers to Cloudflare’s at your domain provider.
I’m not sure how to set up Cloudfare while using InfinityFree’s free hosting.
Read the guide that @Greenreader9 wrote and sent to you earlier. It explains the entire process to you.
This one will be good to read to:
Thanks! I was able to get it! That was easy as pie
