Hello everyone,I am new to InfinityFree and I would like to use my own custom domain, with my free hosting account.I have read that this is possible, but I want to make sure I follow the correct procedure to avoid any issues.
Could someone please confirm the main steps? From what I understand, I need to:
1.Get the InfinityFree nameservers.
2.Go to my domain registrar’s control panel and replace the current nameservers with the ones from InfinityFree.
3.Add the domain as an “Addon Domain” in my cPanel on InfinityFree.Are these the correct steps? Also, where can I find the official InfinityFree nameservers?
Thank you in advance for your help!
Welcome to the forum
Yeh you’ve got it right with how you add the domain:
This article can help further
While a free subdomain is a great way to get started, a website looks a lot more professional with a custom domain name. Fortunately, you can register your own domain name with an external company (like Spaceship ) and use it on InfinityFree.
Adding your domain name to your hosting account
To add your domain name to your hosting account, you first need to have a hosting account. Even if you only want to host your own domain with us, you’ll first need to create a hosting account with a subdomain,…
The name servers are:
ns1.infinityfree.com
ns2.infinityfree.com
and can be found here:
Before adding your domain name to your hosting account, you need to point it to the InfinityFree nameservers. This guide will walk you through the necessary steps using Spaceship as an example. Keep in mind that different domain registrars have different interfaces, so the exact steps may vary.
Step 0: Find the correct nameservers
Before changing your nameservers, you need to determine which nameservers to use. The appropriate nameservers depend on your account type:
For new accounts or exist…
Once you’ve set up your domain, I’d personally recommend using cloudflare’s service to help prevent DDOS attacks
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree.
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com ).
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
Set-Up Cloudflare
Go to Dash…
Perfect, thank you very much. I will read all the documentation carefully and if I have any issues, I will get back to you for clarification.
system
Closed
December 14, 2025, 7:18pm
4
