thedarkintrigue[dot]com
My Aim
- Domain from Hostinger
- Hosting of Infinityfree
- SSL of cloudflare
So, 2 days ago i buyed a domain from hostinger thedarkintrigue[dot]com & i have setup cloudflare with it, I’ve added the nameservers of cloudfare in hostinger. BUT NOW I’M HAVING PROBLEM WHILE CONNECTING IT WITH INFINITYFREE. it shows error when i try to addon domain
Error Adding Domain..
This could be due to already adding the domain to this or another account or, you have not changed the nameservers as required or not enough time has passed since changing the nameservers..
Remember, you need to change the nameservers on a domain via registrar control panel BEFORE adding it to your account, it may take 24~72 hours to completely update the nameservers.:
Please verify your nameservers and/or change them to:
(The nameservers are changed via your domain registrar control panel, NOT your hosting control panel.)
ns1.byet.org
ns2.byet.org
ns3.byet.org
ns4.byet.org
ns5.byet.org
After changing the nameservers you may have to wait 24~72 hours prior to being able to add the domain to your account..
Once the name servers are set it may take upto 76 hours before the domain can be added here.
Name servers MUST be set before adding the domain here, if your registrar REQUIRES that you add a domain before setting the name servers then you will need to use a different domain name / registrar (or contact there support requesting they manually set the name servers). We are NOT able to add domains to the vPanel without the name servers being set firstly.
Alternatively you can create a CNAME record pointing...........
I’ve changed the cname records in cloudflare as per this Post
But this didn’t helped me, its been 48 hours since i edited all of the stuff,
here is the screenshot of my record
