Hello in my control panel I can add on domain such
exemple.ga or exemple.cf or exemple.gq but when I try to add exemple.ml I get an error message which itself is false.
The error message is : “This domain name is not registered, we can register this domain name for you.”
Yet the domain is duly registered. I believe at this time there is a technical bug in adding addon domain such as exemple.ml.
Can someone look into this please so I can host the domain exemple.ml
This same problem showed up for different domains. Always the above error message which is erroneous for exemple.ml.
Hello. Yes.
As written at the begining :
So this issue with example.ml is not related to IDN since thhe control panel accepted xn–lnj.ga, xn–lnj.cf, xn–lnj.gq and other of such different idn I tried.
Is the account pending payment? Suspended? Something got typed wrong?
Everything I see shows the domain does not exist, so the message in the control panel is correct. I don’t know what else to say besides check with Freenom, the issue is on their end.
Thank you very much for your help. Appreciated.
See my above screenshot to answer your questions: "xn–lnj.ml is not registered with Freenom. Is the account pending payment? Suspended? Something got typed wroIs the account pending payment? Suspended? Something got typed wrong?
Again my original message: This same problem showed up for different domains. Always the above error message which is erroneous for exemple.ml.
(meaning not wih .gq .cf .ga)
Always refresh the page a couple of times, because Freenom’s WHOIS can erroneously give that error.
I also receive the same message (This domain name is not registered, we can register this domain name for you.) on the Control Panel (by trying to add Addon and Parked Domain).
I would say to try creating a new hosting account, but when I tried creating one on the Client Area:
Do not challenge us. You should confront Freenom. This issue is on their end.
Freenom always have this kind of flareup once in a while. This is not within our control
