Domain Pointing
It does not matter if your domain is pointed to an IP address. You have to set the correct nameserver in order to registrar your domain with our system. If you just point the domain to an IP without registering it, you get the page you are currently seeing.
So once again, you cannot host a .com.br domain here due to restrictions by the registry
in this case it would be because it is the free version? if I buy hosting can I put this .com.br domain?
It looks like .com.br domains won’t work with premium hosting either (See here), but it may be worth contacting support.ifastnet.com and asking them directly.
Yes, that will work. cPanel lets you add domains to your account without having to configure nameservers ahead of time. So you can add the domain to your account first and set the nameservers after, and they will pass the check from the .com.br registry because the nameservers are already configured.
Is there a way to place an ad platform on my website, such as the monetag, and after it is approved, I intend to place the adsense ads, is there a way to place it on my website like this?
the problem is that this platform, monetag does not accept a free domain, that’s why I bought a .com.br domain, but I couldn’t put it here, because from what I understand the infinityfree platform does not accept a .com.br domain, right?
But if I buy a .online domain, will I be able to place the ad platform on my website, and will I be able to place the .online domain on infinityfree?
Can you please help me Adm, my situation is simple, I just wanted to put a personalized domain, but I bought .com.br, from what I saw in the community, .com.br is not accepted, I wanted to use it in order to monetize my site, with the Monetag platform with you, but it cannot be a free domain, that’s why I bought the .com.br, but it doesn’t accept it or can you put it for me? it would help me a lot, because I already broke my head a lot, if there is no way, I would like to know if you accept the .online that I am going to buy to put it on. it helps me
.com.br domains are not supported here, you can’t use them with this platform at all. If you want to use .com.br, you will need to upgrade to premium hosting.
Assuming you buy a .online domain from a provider that does not require DNS checks, you can host a .online domain here. For example, NameSilo and NameCheap domain providers are a good choice to buy the .online domain from. You can use .online domains with both free hosting and premium hosting.
Okay, I already made the note for here, now should I do something here? I bought a .online and changed the server names to ns1.epizy.com and ns2.epizy.com it worked now do you need to do something here or is it already right?
If you connected it to your account, you are ready to go!
still not connected, I just changed the user names, I did it on hostinger, here you don’t need to do anything? just wait for the propagation?
It can take 72 hours from changing your nameservers with your domain provider before our system detects the change and allows you to add the domain to your account.
How will I know if it’s ready? And after propagating, do I need to do something, like change something here or does it already automatically recognize the domain there and change the one here?
When the system allows you to add the domain name
Can you send me a print of where I do this here at infinityfree please, because I’m trying to access the panel and it’s not working, it’s out of order?
Please see the pinned topic
Now it worked, but I can’t access the panel to assign the domain to a hosting account, do you know why I’m not able to access the panel to make this change? or can you do it for me? look at the print
Read
when you manage to access the panel to change the domain there, I need it
That’s up to you! We don’t control the contents of your website, we don’t dictate which platform you should use to make your site and we don’t control which features are possible in the platform you have chosen to build your website.
So whether this is possible depends on how you’ve chosen to build your site.
For basically everything: no, we can’t do it for you. Either you can do it yourself or it can’t be done at all. If the platform doesn’t let you add your domain, it means the domain cannot be added. And if you can’t add your domain name right now because the control panel is down, it means we also cannot add your domain because the control panel is down.
Yes, everyone needs the control panel for various reasons. We’re aware of the issue and are working to get it fixed.
