i am using .com domain from Hostinger
Read the guide
No info = no help
broâŚits showing in my self signed certificateâŚexpiry date which i sent u earlierâŚi am not lying
In order to get help, you have to show some effort.
Without providing the info we requested
We are not obliged to help.
Hence
appliesâŚ
Because your website is probably not currently through a Cloudflare proxy (not orange cloud)
self-sig cert serves for INTERNAL communication between CF and ORIGIN
not for visits to your website directly via browser.
Or your browser cached the certificate (old self-sig)
And please stay on topic - discussing certificates etc. is offtopic
found this guide helpful on setting up cloudfare
can i do * for all of my wonderful subdomains
as in * is universal so https://example.dznv.online
why does that say suspended??
Because you canât do:
You need to add them in individually.
so i gotta do alfie @ www and allat in the dns redirecting to the ip?
like this it still doesnt show the website on my domain?
the thing worked before this idk
Thank you, but I was already using the âAlways Use HTTPSâ The problem lay in the DNS setup, cloudflare fetched all the unnecessary records from Infinityfree DNS so I had to manually remove and set up new records, but now everything is working perfectly.
Youâre responding to a post from two years ago, when the initial post was made the information shared wasnât included in the original article, so the post mentioned them for inclusion.
2 posts were split to a new topic: CloudFlare DNS Records
Awesome! Thank you for the guide! ![]()
SSL handshake failed Error code 525
The âSSL handshake failedâ error usually means that you have configured Cloudflare to use âFullâ or âFull (strict)â, but no SSL certificate is installed.
This guide goes into more detail about that:
What even is Cloudflare?
Found this on Google in a couple milliseconds
A post was split to a new topic: Started using cloudflare but our website is not coming up
i did these steps but its not working the site went down and in the dns section of infintyfree dashboard it shows that neither the ip adress or the record one is working correctly*
Please open a new topic and provide your domain name and screenshots
