I am unable to connect to wp-admin. due to this, I am unable to perform any changes to the wordpress website. need help.
http://yogachallenge.co.uk
yogachallenge.co.uk sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
Your website doesn’t seem to resolve for me or most major DNS providers at the time; have you set up Cloudflare correctly?
Step 3: Set up DNS Records for sabkuch.co.uk
Please set up the following CNAME record on your domain name. This record is necessary for the certificate provider to verify you own the domain name.
Your domain name is using Cloudflare nameservers.
Please add the CNAME records to Cloudflare’s DNS. Make sure the records are set to “DNS Only”.
Which domain are you trying to set up - yogachallenge or sabkuch?
Sabkuch gives me ERR_TOO_MANY_REDIRECTS - this is usually caused by an SSL misconfiguration:
WordPress is a great and very popular website building tool, and Cloudflare is a great way to get HTTPS on your website for free. Thanks to Cloudflare’s Flexible SSL system, you don’t even need to manage SSL certificates to use it!
However, getting WordPress to show a padlock and make all pages work can be a bit tricky. This article explains a good way to configure your website correctly with Cloudflare Flexible SSL.
Heads up! Instead of making WordPress work with Flexible SSL, you can also c…
Have you done that?
Admin
October 28, 2023, 3:29pm
7
The domain yogachallenge.co.uk is down because there are no DNS records for the domain in Cloudflare. Please make sure the necessary DNS records are set up as described in this article:
Hello,
I will show you how to easily set up Cloudflare, Edit Records, and Troubleshoot with images!
PLEASE READ BEFORE STARTING!!!
Cloudflare cannot be used on free subdomains from InfinityFree.
You can use Cloudflare on Custom Domains (yoursite.com ) and with Custom Sub-Domains (subdomain.yoursite.com ).
A video tutorial can be found at the end of this guide, should you get stuck.
You must connect your domain to your InfinityFree account first. Read more here .
Set-Up Cloudflare
Go to Dash…
Thanks, will look into it
