I have added a subdomain to my website using infinity free but my nameservers are of cloudflare so should will my subdomain work? if not then why?
You can’t add a subdomain to cloudflare…
If you have a subdomain of your main domain (eg. sub.domain.com), just set it up in cPanel (which you did) and then login to Cloudflare and paste the IP in the A record fiels for your subdomain.
Example:
But if you used a free subdomain,
Just uncensor the domain so we can diagnose…
It should be. Maybe check against this too:
Also, do you mind sharing the domain please?
okay… its thedailybites.thespacedust.com
what does that mean?
“(post withdrawn by author, will be automatically deleted in 24 hours unless flagged)”
like i cannot use custom domain for my subdomain? Right?
@FlutterHoney, that topic is for subdomains without a main domain.
@anon70553301, you should be able to do it. Have you added the subdomains to the “Subdomains” section of the control panel?
Can you please provide a screenshot of both the subdomain section of the control panel and the Cloudflare DNS page?
Please let me know if you have any questions!
The “post withdrawn by author, will be automatically deleted in 24 hours unless flagged” message means that the post creator has deleted the post, and it will be deleted in 24 hours.
I delete a post. Ignore it.
You are good privacy wise!
Let me take a look
Ok.
You are good so far, you just have one more thing to do! All you need to do is add one more DNS record to Cloudflare.
TYPE: CNAME
TARGET: thespacedust.com
Make sure the cloud is orange, and TTL is set to “auto”!
Fine.
ok let me check
Oops. yes, that is correct!
