SSL Problem
Hello everyone. I’m new around here and I’m an amateur. I created free ssl certificate for my web page. I followed all the steps correctly.
While adding the private key and certificate codes, I generated CSR code and screwed things up.
I see the SSL certificate not found error and I am not configuring the certificate keys . Also , I no longer have a Cname record . I’m waiting for your help .
If you have a private key and certificate, there is no need for you to generate a csr. Just create the CNAME record again and when it verifies, install the private key and then the certificate.
