Connection is not secure
I installed a SSL certificate via the infintyfree account and I also added my site on cloudfare which ig automatically installs an SSL. However I paused cloudfare when It didn’t work and it’s still paused. These are all the things I did and still HTTPS isn’t working.
If you want to keep the SelfSigned cert, setup your CF SSL mode to “Full”, and make sure the orange cloud is enabled on the A records pointing your domain to IF.
Ok well I changed SSL mode to full (and bruther I literally told you I paused cloudfare that’s why you think it’s false). But I don’t understand what you mean after that. I checked and the A records and other stuff are there but I don’t see any orange cloud . Https still didn’t work after changing SSL mode to full
Also I removed the SSL from infintyfree in case that’s interfering . I used to use 000webhost but that would always allow SSL when I added my site to CF and I didn’t have to install anything from the web host. So yeah, I removed it from infintyfree
