Ssl not working
my site is http://tscollaboration.ml
i got ssl certificate from Infinite free(Its all done).then i’ve goto control pannel then ssl/tls
and clicked configured.then entered private key and pressed upload and entered certificate and press upload certificate.
My problem is i haven htts/ssl yet.www.sslshoper.com says “certificate not found”.
can you help me for the solve this error?
hi isuru_liyanage
the thread for similar problem has been posted many times by other user. it’s seems like outage may affects your page.
you can wait for now.
Hey there. A lot of people have been commenting on this, but can you try the steps in this video before we call it an inter error?
Thanks.
hi @greeenreader9, I’m facing same issue as well. i had followed those steps. and i believe @anon75812324 also already tried it.
as you can say, the video only the visual guide to :
Thanks @anon87716363 foe the confirmation. I believe that there is an ongoing SSL error at this time. Unfortunately, we don’t know when it will be resolved. But please do not create additional topics, or request a ton of certificates (because when it will come back online they will all be piled up and cause an error)
Thanks.
yes, @anon87716363 im already tried like this video (posted video @Greenreader9).but problem is not sloved
@anon75812324 indeed. and please check the forum before post exact same issue. please check by searching the topics before post. all we could do now is wait :smiley:
check @Greenreader9 reply above
thank you both of you. thank you very much @anon87716363 @Greenreader9 .
