I have set up a free SSL on my free hosting with free subdomain, but it didn’t work. What can I do?
The site is this, and I have used the GoGetSSL directly from my client area
i have the same problem
Hello @OverloadedTech, can you please give a screenshot, and tell us what step you are stuck on? The same goes for @anon35825477
Thanks.
The screenshot of what??
The SSL page…
Anyway, I believe this is an internal error, there are a ton of people with the same issue. Please refer to the topic below.
Thanks.
Solved
You don’t need to say that. It makes me think you were able to get the certificate working. The “Solved” button is there so you don’t need to reply.
Thanks.
