This is my second SSL certificate and when I put in the information for the CNAME record it’s never detected. I copied them over perfectly. It’s been almost 36 hours since I put them in and nothing.
No other forum solutions have really helped me with this issue.
Imgur Screenshots
Do I need to leave in the extra mc-tick.pro when copying over?
KangJL
November 18, 2023, 2:55am
4
This
and this are different
You need to change to IF nameservers first.
Before adding your domain name to your hosting account, you need to point it to the InfinityFree nameservers. This guide will walk you through the necessary steps using Spaceship as an example. Keep in mind that different domain registrars have different interfaces, so the exact steps may vary.
Step 0: Find the correct nameservers
Before changing your nameservers, you need to determine which nameservers to use. The appropriate nameservers depend on your account type:
For new accounts or exist…
Anyway, domain is not added to any IF hosting account. Why would it work?
the site shows up fine https://mc-ticks.pro/ but I will try changing the nameservers…
system
Closed
November 25, 2023, 3:04am
7
