Softaculous is temporarily unavailable - Need Help
https://sv1.scriptinstall.rocks:2083/cpsess1850416317/frontend/meridian/index.html?login=1&post_login=63818472963387
Softaculous is temporarily not available. This could be because your account is not active or because you have reached the inode limit. If this issue persists, please contact us on the Community Forum.
I am trying to access Softaculous from my control panel to install a script, but it is showing a message: ‘Softaculous is temporarily unavailable.’
Which hosting account are you opening Softaculous from? Please give me the username (it looks like if0_12345678) or the domain on it. Your profile has more than one account, and the control panel link you posted doesn’t show which one it is.
The error gives two possible causes: the account isn’t active, or it has reached the inode limit. Which one applies depends on the account. One of your accounts is suspended (at your request) and the other two are active. It would also help to know the inode count your control panel shows for the account.
An earlier topic with the same message turned out to be an account that hadn’t been set up correctly. The fix there was to remove the domain, deactivate the account and create a new one. Yours might be the same problem, and the account name and inode count would show whether it is.
The earlier topic with the same message and the fix I mentioned:
if0_43180242
What is your site’s current inode usage? As the error message you shared points out, that’s one of the possible causes. Softaculous creates some temporary files on your hosting account whenever you open it, so having too many inodes can prevent it from working.
