Am i able to add TXT and MX records in a free plan?
Yes, you are. You can add MX records through the section in vPanel, and TXT through the section titled “SPF records”. Please note the if you have more than one TXT record that you need to set up, you will have to find a custom domain and DNS provider (such as Cloudflare) because our SPF tool only supports one record.
but if i add cloudflare nameservers i will lose my my cpanel here? Or can i add epizy nameservers and cf?
If you have a custom domain and wish to use Cloudflare for DNS zone management, you can follow the guide linked below. It will show you how to set everything up correctly.
