I was wondering how to add things like custom buttons and catagories and change CSS stuff using the MyOwnFreeHost panel. Is there any way that i can change stuff in the cpanel?
I don’t think you can change the panel, I think that’s all set up by iFadtNet.
Officially, MOFH doesn’t support any changes in vpanel but it can be done by adding some js into adcode section in myownfreehost panel.
You may refer to this post:
thats pog, might try it out
