Problems with transferring a site from localhost to InfinityFree
https://testallsitetoday.42web.io
Hello. Your help is needed.. I’m migrating the site from xampp(localhost) to InfinityFree. I uploaded the files and the database, but when I open the site, https://testallsitetoday.42web.io says “Error, establishing a database connection”. I need your help very urgently.. Thank you!
This might help you…
Keep in mind that InfinityFree has some Scripts, and a “live” website is different from a LocalHost.
Also, check if you have the databases, and that there is a file limit:
Update:
It seems fine now. You may supress this post :slight_smile:
