Problems with the page
www.quinem.com
There has been a critical error on your website. Please check your site admin email inbox for instructions.
Maybe your WordPress is corrupted:
ok.
I also have no access to wp-admin
Hi, I couldn’t connected to server from FTP. Timeout conection error.
I looked at the note but I can’t solve the problem:
Estado: Desconectado del servidor
Estado: Resolviendo la direcciĂłn de ftpupload.net
Estado: Conectando a 185.27.134.11:21…
Estado: Conexión establecida, esperando el mensaje de bienvenida…
Respuesta: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Respuesta: 220-You are user number 257 of 6900 allowed.
Respuesta: 220-Local time is now 19:44. Server port: 21.
Respuesta: 220-This is a private system - No anonymous login
Respuesta: 220 You will be disconnected after 60 seconds of inactivity.
Comando: AUTH TLS
Error: La conexión superó el tiempo de espera después de 20 segundos de inactividad
Error: No se pudo conectar al servidor
Estado: Esperando para reintentar…
Respuesta: 220-You are user number 259 of 6900 allowed.
Respuesta: 220-Local time is now 19:45. Server port: 21.
Comando: AUTH TLS
Your site is working fine on my end. Also, admin panel is accessible.
That looks good, But it might be a firewall blocking the connection.
The error you’re seeing is fairly common, but sadly not something we can fix. Here is more information and some workarounds:
Everyone, thanks. I used Online File Manager, I replaced wordpress files and it is already working.
