Probleme with Admin page Opencart 3.0.3.8
epiz_31859028
lesfousdedisney.great-site.net
Loop on Admin panel Opencart
Hi,
After install opencart with my file 3.0.3.8 when i try to connect on admin panel, it’s loop. Impossible to access admin panel open cart. If i try with false password i have an error and with true password it’s loop on the admin page.
What is the proble ?
Thanks
check your error logs?
https://forum.opencart.com/viewtopic.php?t=16658
i don’t have the log directory.
The problem is when i inputing the credentials, it’s return on the admin page, impossible to enter on admin page
i found this info for the admin loop but its for 3.0.3.2 , maybe its the same issue ?
You need to set your php time and mysql time the same. its deleting cookies to soon. You can fix this.
Open:
system/config/default.php
system/config/catralog.php
system/config/admin.php
Find:
$_['session_engine'] = 'db';
Replace
$_['session_engine'] = 'file';
theres also this thread about installing opencart that might help OpenCart Solution
