I have been searching for a way to install OpenCart in here, but failed many times. I switched to AbanteCart.
But today I used my brain (sometimes works) and found a solution and OpenCart is now working.
The error comes in admin panel which won’t redirect you to dashboard, then change this line in system/framework.php
line no. 112
setcookie($config->get('session_name'), $session->getId(), ini_get('session.cookie_lifetime'), ini_get('session.cookie_path'), ini_get('session.cookie_domain'));
Change it to:
setcookie($config->get('session_name'), $session->getId(), time() + 60 * 60 * 24 * 30, ini_get('session.cookie_path'), ini_get('session.cookie_domain'));
I used a subdomain, so don’t know about normal domain.
Just do this:
And one more thing, AbanteCart is more flexible but harder to learn, but it is also very good choice if you find OpenCart too simple , if you have good knowledge of API’s and PHP then go with AbanteCart .
Edited 8/8/21 to correct spelling and grammer
