Hello,
I still have problem connecting via ftp. I manage to connect without SSL/TLS using winscp but not with SSL/TLS
Filezilla can’t connect in both way (without SSL/TLS or with SSL/TLS)
what is the problem?
Hello,
I don’t get the same answer for both SSL and non-SSL connection on Filezilla.
Maybe infinityfree doesn’t support SSL/TLS FTP connection?
thanks
Since you did not write clearly, please provide the info using below guide.
thanks,
here are the log of filezilla when explicit SSL/TLS is on for filezilla :
| Status: | Resolving address of ftpupload.net |
| Status: | Connecting to 185.27.134.11:21… |
| Status: | Connection established, waiting for welcome message… |
| Response: | 220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- |
| Response: | 220-You are user number 294 of 6900 allowed. |
| Response: | 220-Local time is now 13:39. Server port: 21. |
| Response: | 220-This is a private system - No anonymous login |
| Response: | 220 You will be disconnected after 60 seconds of inactivity. |
| Command: | AUTH TLS |
| Response: | 502 AUTH TLS OK. |
| Command: | AUTH SSL |
| Error: | Could not connect to server |
Did you login with correct userid and password?
Yes because when I cannect with WINSCP or Classic FTP both without SSL/TLS, I connect successfully via FTP
when I connect with filezilla without SSL/TLS, I also can’t connect and get those logs :
| Response: | 220-You are user number 297 of 6900 allowed. |
| Response: | 220-Local time is now 13:52. Server port: 21. |
| Status: | Plain FTP is insecure. Please switch to FTP over TLS. |
| Command: | USER epiz_25700656 |
| Response: | 331 User epiz_25700656 OK. Password required |
| Command: | PASS ************** |
| Response: | 230-Your bandwidth usage is restricted |
| Response: | 230 OK. Current restricted directory is / |
| Command: | OPTS UTF8 ON |
| Response: | 200 OK, UTF-8 enabled |
| Status: | Logged in |
| Trace: | Measured latency of 791 ms |
| Status: | Retrieving directory listing… |
| Command: | PWD |
| Response: | 257 / is your current location |
| Command: | TYPE I |
| Response: | 200 TYPE is now 8-bit binary |
| Trace: | Retrieving external IP address from http://ip.filezilla-project.org/ip.php |
| Trace: | Got external IP address |
| Command: | PORT 77,204,106,240,220,171 |
| Error: | Disconnected from server: ECONNABORTED - Connection aborted |
| Error: | Failed to retrieve directory listing |
This seems to be an issue. The message says TLS is OK, but the status code should be 234, not 502.
In this post, a person who seems to be one of the people behind FileZilla says it’s caused by:
There’s a bloody damn broken firewall actively sabotaging the connection.
I’m willing to believe that.
Can you please try connecting from a different network, or over a VPN and see if that helps? If it does, it does mean there is a firewall on your end breaking secure FTP.
I will try
thanks
