No. You can still use it ![]()
Yes but i cant use it for Cloudflare
You can’t use subdomains with cloudflare, yes.
But this doesn’t mean that you need to give it up. Just add a CNAME record to your new eu.org or pp.ua domain, pointing to your old belk.epizy.com . (Should work)
So i will be able to use CDN for my already existing domain?
No, only your new domains can be on cloudflare.
You might wanted to give up your old domain eventually. Anyways it was only a free subdomain that you can’t really control.
How else can i set up a CDN for my website then? eu.org doesnt accept domains most of the time
Are you sure? Did you receive the request rejected reply?
i bought the pp.ua domain, i didnt try eu.org . The website looks like it was last updated in 1996 and it takes weeks for you to get applied i heard
Freenom has not allowed new domain registrations since March 2023, making this article irrelevant.
