Not able to remove directory privacy
https://thebeeboi.lovestoblog.com
error 9349345835eg please contact support /home/vol14_6/epizy.com/epiz_32911720/htdocs/wp-admin//.htpasswd.89179dec12d4335f81fc3311526ee2bc
I was trying to remove directory privacy from my wp-admin folder
If you added that from Vpanel, you should be able to remove it from there too
I tried, but it gave me the error above: error 9349345835eg please contact support /home/vol14_6/epizy.com/epiz_32911720/htdocs/wp-admin//.htpasswd.89179dec12d4335f81fc3311526ee2bc
Of course, the names of the directories and other things are different in your case but use common sense.
If you want to use that option, you can try this version (which is more advanced).
It is located in the Client Area on the left side menu.
