Necesito ayuda con Error 525: El protocolo de enlace SSL falló
El enlace es:
https://comprartecladopiano.gq/
Esto es lo que me sale
Necesito ayuda, ¿cómo puedo arreglar esto?
Please speak in English next time! Here is the translation:
Please read this topic:
¿Y que puedo hacer?
I said, please speak in English! Here is another translation:
On the bottom of the topic I linked to there are some workarounds for Cloudflare to make your website be available also over HTTPS, or if you’re lazy and want to not read that topic to see what happens and what can you do to solve the problem here is the first workaround, with also the instructions to set the WordPress URL from HTTPS to HTTP via the database phpMyAdmin. Go to your Cloudflare dashboard, click on your domain, go to “SSL/TLS” and set the SSL option to “Flexible”, then go to your Control Panel, click on “MySQL Databases”, click on “Admin” next to the database you want to access phpMyAdmin, and follow this guide except for browsing the database in phpMyAdmin to change the WordPress site URL from HTTPS to HTTP. Do the steps of browsing the database and changing the website URL from HTTPS to HTTP only if you have WordPress installed.
