Nameservers are not working on godaddy
I can’t change my nameservers on godaddy it says invalid nameserver but I used ns1.infinityfree.com and ns2.infinityfree.com, godaddy said to ask for your hosting IP and DNS records since the nameservers are not working
You can get the IP from your dashboard, but the way the housing is set up pointing the domain at the IP address won’t work.
If the name servers aren’t working, you can try using a cname record instead. This article should help:
