https://artisticwebsitesolutions.web1337.net/wp-admin/admin.php?page=kubio&postId=41&postType=page
Warning : mysqli_real_connect(): (HY000/1203): User if0_36745128 already has more than ‘max_user_connections’ active connections in /home/vol6_2/infinityfree.com/if0_36745128/artisticwebsitesolutions.web1337.net/htdocs/wp-includes/class-wpdb.php on line 1987
User if0_36745128 already has more than 'max_user_connections' active connections
This either means that the username and password information in your wp-config.php file is incorrect or that contact with the database server at sql311.infinityfree.com could not be established. This could mean your host’s database server is down.
- Are you sure you have the correct username and password?
- Are you sure you have typed the correct hostname?
- Are you sure the database server is running?
If you are unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress support forums.
I have tried editing the WP-Config file with the MySQL Database configuration information, but with no success. I have made a backup, in case I screwed something up. Please help?
