My websited appears to be blocked (and without suspension)
http://kgames.great-site.net/
This site can’t be reached
I got an email on 3-24-2025 (but just found it today in my spam folder on 3-26-2025) that said:
“This email is to notify you your site (epiz_31576195) has used over 50% of its daily hits!”
And this was approximately when I could no longer access my site. This happened once before but the issue was resolved without my input within 24 hours.
Thanks for looking into this.
Your website works fine for me. Try a different network/device.
Works fine for me
Try clearing browser cache (shift-click reload), or just wait a while. DNS caching could be the reason if it actually got temporarily suspended
I checked all of your pages and Happily It works fine. I think It’s a cache problem. So do the hard refresh. Also If that didn’t work try a different browser
Thanks for all the responses! I’ve had no luck yet in fixing the problem. Here is what I’ve tried:
  1. I went into Debug mode on Chrome and right-clicked on the reload button and selected “Empty Cache and Hard Reload”
  2. Restarted my my router.
  3. Tried Firefox.
  4. Tried my second computer.
  5. Tried a tablet. (It just hung.)
  6. In a Windows Command window running as Administrator entered “ipconfig /flushdns”
  7. Deleted all the cookies for the site.
  8. Right-clicked on the icon to the left of the URL in Chrome. Selected Site Settings. Clicked Reset Permissions (A lot of the drop-down lists show Block and are disabled). [I think I will check my wife’s computer after she gets home to see if the Site Settings are the same.]
I think my next step is to find info on my router and either do something with it via software on my computer or use a paperclip on a button on the router to do a more thorough reset.
P.S. (Probably unrelated) The browsers state my site is “Not Secure”. When searching InfinityFree I came across something that said something along the lines of getting a free SSL. I may want to investigate that.
Does your ISP or DNS resolver have a service that blocks malicious sites? Some of them will block all of InfinityFree’s free subdomains.
You might want to try accessing your website on a different network or while using a VPN. If you can do that successfully, that means it’s definitely an issue related to your network.
Since your error message says the site couldn’t be reached that’s likely unrelated. But it’s a good idea regardless.
Update: I couldn’t find any way to tell my router to stop blocking my sites so I called XFinity(Comcast) which is my ISP. I recall that I had this problem before and they have a website in which you can tell them to unblock certain sites. This worked before. I was on the chat with them for over 2 hours and went through 4 technicians, but I was finally able to submit my request to them. That was 6 days ago and my sites are still not available. I guess I will keep waiting or perhaps submit my request again.
I had similar issues with my ISP. I ended up getting a pp.ua domain. Free domains are blocked by ISP’s far too often for my taste :confused:
if you cant access your website try using a VPN or a proxy
if you don’t know what a proxy is, a proxy is basically a different browser that uses a different IP address so try to use a VPN/proxy
