https://unispournosenfants.fwh.is
Unable to connect
Same problem as the one described here : My subdomain is offline on july the 18th.
It’s not the same error. This time the issue seems to be with your SSL certificate. As this is something you can’t control, admin will look into it when he comes online.
@Greenreader9 : Who were you talking to? Me or nanobutano? I didn’t touch the SSL certificate.
Same goes with mine. I think it’s the site-wide Free SSL Certificate that has an issue. My website works pretty well with “http” but not with “https”. Hope this gets resolved soon.
To you @UnisPourNosEnfants . You don’t have control over the certificate so it could not have been your fault. It’s probably a server issue.
An outage topic has been created for this issue, please refer to it for additional information.
SSL Outage on some free subdomains
Starting around midday July 22nd (UTC), some free subdomains began to experience issues with their installed SSL certificates.
Which components are affected by this issue
Free subdomains
What issues may you see
SSL Error
Unable to establish a secure connection to the server
When will this issue be resolved
We are doing our best to get these issues resolved as soon as possible. Unfortunately, we don’t have enough details to tell how soon that will be.
What…
