I am add a SSl certificate by infinityfree ( Lets encrypt ) . Then I am revork zero ssl and add cloudflare ssl but it is not working .
I will remove this ( lets encrypt ssl ) but it is not remove and add cloudflare
Please Help Me To FixThis Problem
No info = no help
please Help
my site - mediauniversitylk.com
Follow this guide
How are you trying to setup SSL? Do you only want Cloudflare, or do you also want a certificate here (It is more secure if you have it in both places).
I want to add my site to auto https:// Without redirecting Like Cloudflare
I was install normal ( zero ssl ) not a cloudflare
Please Help Me to Fix This Problem
Please stop multiple posting!!
Write clearly and provide more info
can i add my site to auto https without redirecting
If you type in https there will be no redirect
okay It seemed to me that you did not know the answer to this
Thanks For Help!!
Do not reply again
You must learn to ask correct question.
If user type in https, there will be no redirect
If http was typed, redirect will of course take place. (HTTPS enforcement)
This is assuming SSL was installed in the first place.
You may read below for more info
