Monsta FTP 077
Username epiz_33485768 | Website URL
I Accidentally set the folder i made to 077 while i was trying to change it to 777.
How can i fix this?
CHMOD -----------------------------------------------------------
Are you able to set the owner permission again?
If not, try setting it via FTP.
If still fails, you should contact iFastNet.
Okay I’ll try this :grin:.
It didn’t work i got this error when i used the ftp :
Command: CWD /htdocs/inc/plugins
Response: 250 OK. Current directory is /htdocs/inc/plugins
Command: PWD
Response: 257 /htdocs/inc/plugins is your current location
Command: DELE temp
Response: 550 Could not delete temp: Invalid argument
Status: Retrieving directory listing of /htdocs/inc/plugins.
: Still thank you for your suggestion.
There is nothing we can do
You may want to create another hosting account.
Remember to de-activate the current problematic account
Okay i will search this forum on how to de-activate the account. Thank you :grin:
This may help
I successfully deactivated the account.
Thank you @KangJL !.
