I wish to use AJAX post requests to fetch audio/video blobs from the user every N seconds. This site is only for personal testing purposes, so at most only one or two people will be using the site at at the same time.
My question is, what is the maximum alowed value of N that I can use without getting banned? 0.5? 1.0? 5.0?
This is not a question on how to game the system. I see now how using the phrase “without getting banned” would give someone that impression – I shouldn’t have, and I regret the misunderstanding. But this is a question regarding what is allowed per the rules of this service.
However, that same link makes it very clear:
DO NOT USE AJAX CONTINUOUSLY IN THE BACKGROUND
If you’re using InfinityFree, your account will get suspended in no time
I’m afraid I don’t understand your suggestion of “You have to trial and error on your own”
My question was “How many AJAX post requests of audio/video blobs am I allowed to make per second?”
I don’t see how I can test that without increasing the volume until I get banned.
My best guess is that you should delay it for 2 seconds. If you make Ajax requests every second, you’ll likely make 60 requests per minute for each user, so with that, you said your game will be tested with two people, which will overwhelm the available resources of the server if users are playing continuously, which will lead to suspense. And keep in mind that the allowed number of hits per day is 50K. The method I mentioned was perfectly fine for me. Or you can store the audio in local storage and use them when needed without making any server request.
This may not be an applicable use case for free hosting.
Take note IF is meant for webhosting.
Audio/video blobs may be stretching the limits of free hosting
I’m not making a game, just trying out some coding related to live audio/video transfer. And to address @KangJL 's concerns, I will state once again that this is just some personal testing by me, I would not try to stream audio/video to multiple users while on a free account.
Yes, fair usage limit applies
Sounds like how to game the system to me
My intention was to ask what exactly that limit is to avoid unintended violations. Although reading through the links you provided seems to indicate that keeping limits confidential to avoid users skirting them is standard policy, so I’ll accept it.
Thank you very much for the links, however, they were very useful: the limit on processes, IO, and RAM will apply to my use case. The link on IO says you can view how close you are to the limit through the graph in the Account Statistics page in your control panel. Can one check their process and RAM usage as well? It would be nice to know the usage level before you hit the limit.
I’m just testing stuff out for now, I will decide later whether to share this site with the public. And if I do decide to have this site be for public use, I will obtain the required hosting plan.
But for now, I am only testing stuff out personally. If this is still not permitted, kindly link the relevant section(s) of the ToS.
Ah, I was not aware that streaming was disallowed. I don’t really have an exact idea of what I’m building, since like I’ve said, I’m currently just trying to learn and test the technologies and coding underlying audio/video.
If I collect live audio/video blobs from the user’s mic/camera, process them, and return some output to the user (say detecting the dominant frequency or color), I believe that would not be streaming? And would be allowed?
EDIT: I forgot to reply specifically to your message, so I’ll tag you instead @KangJL
@KangJL Web hosting need not mean just static pages. Considering the fact that PHP, MySQL, etc. are provided, hosting more advanced websites doesn’t seem unreasonable.
I have already said my piece.
You can do it at your own risk.
Please don’t think I’m being obstinate. Recall that I immediately accepted the restriction on streaming, since you backed it up with an excerpt from the ToS.
I quickly read through the ToS just now, and the relevant section seems to be the
Script Usage Terms
Scripts on the site must be designed to produce web-based content, and not to use the server as an application server.
But due to server-side scripting languages like PHP, the distinction between a web server and application server is fuzzy. The examples of prohibited uses in this section are:
Using the server to generate large volumes of email from a database is an example of activity that is not allowed.
Scripts that are designed to provide proxy services, anonymous or otherwise, are not allowed.
Scripts that send bulk email or perform processor intensive database processes are not allowed.
Certainly processing user input in amounts that do not violate the resource usage limits, and returning the output as web-based content is not disallowed?
It would be nice to get an official clarification.
I previously mentioned that this site is for personal testing only and will not be shared with the public unless I obtain a hosting plan that supports multiple users. Even if ajax post requests are being made every few seconds, as long as only one or two users are using the site, the 50000 hit limit (and other resource usage limits) will not be exceeded.
Yes - it is debatable (if you are looking at only one item from TOS and not as a whole)
Because you can make your website use a microphone
and depending on the decibel level, your PHP script in the background generates 3D images as a background image for your web page and this is refreshed quite often
what I mentioned is web-based content
But that simply exceeds the possibilities of the free hosting service because it simply consumes too many resources and can be interpreted as abuse
you will probably see 508 errors in the console log first
