Call to undefined function Joomla\CMS\Filesystem\set_time_limit()
My website started to give the set_time_limit error 2-3 days ago but before that it was working completely fine.
This issue is still going for 3 days so I decided to make a post about it, I saw the function being disabled and Joomla is not working without this function. I assumed the function was disabled because the PHP Upgrade and will be activated but my website is still down.
What can I do to make Joomla work? I hope nobody just tries to exploit the website while its not working because I think its unprotected right now because of the outages.
If youâve found a new hosting provider, you can ask them. Alternatively, this guide works for moving websites to InfinityFree, but parts of it apply for moving out as well:
here is how to fix it;
go to htdocs/libraries/src/Filesystem/Folder.php
and delete the set_time_limit functions (the whole line that function is being used)
then go to htdocs/administrator/components/com_scheduler/src/Scheduler/Scheduler.php
search for â// Letâs try to avoid time-outsâ and delete the whole âifâ function.
this should work if you installed joomla from softaculous and getting this error.
Hello. Thank you for your support.
I tried it but:
-When you say âdelete the set_time_limit functions (the whole line that function is being used)â do you mean that I have to delete the text â@set_time_limit(ini_get(âmax_execution_timeâ))â?. I can find 3 of those texts, at lines number 44, 310 and 615.
-I donât have a com_scheduler folder at Components.
Thanks.
EDIT: I got it! I just deleted those lines (nothing about missing com_scheduler folder) and the issue is gone!
