Issue with Secure Connection on My Website
https://twex.great-site.net/
twex.great-site.net sent an invalid response.
  • [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
Hello,
I’m experiencing an issue with establishing a secure connection on my website. When trying to access the WordPress control panel, I receive the error message “Unable to establish a secure connection to the server.” Could you please assist me in resolving this problem?
Thank you very much!
Please do these
i did evrything like u said and SSL Certificate is active and evrything its okey i did exactly like in tut
why now im getting Error establishing a database connection on my webisite??
Please do this
What do you see?
what i do now
Please check
Your user info is definitely wrong
i fixed it and evrything its okey now thankss for helping!
but i lost my webiste ;((( do i have to buikld anotherone ? i took no sleep 2 days building it is there anything i can do to recover old data ?
Thanks again,
How so? Both installing an SSL certificate and updating database credentials should not result in your data being lost.
A quick look at your account tells me that you have created a new database and installed WordPress to it. That’s good news, because that probably means that your site is still there, you just chose to basically setup a new site alongside it.
In the wp-config.php (where you also edited the debug mode), you can find this setting:
// ** Database settings - You can get this info from your web host ** //
/** The name of the database for WordPress */
define( 'DB_NAME', 'if0_36562413_xxxx' );
Simply replace the xxxx (or whatever is currently there) with the name of the database that your site was previously installed on (which is if0_36562413_wp655, looking at the screenshot), save the file, and your old website should be back just like you left it!
Thank you guys for your prompt and effective assistance with my website issue. Your help was greatly appreciated!
Best regards,
