i can not access to Admin URL wordpress
and i can not see my website
Next time, if you have problem, could you please select the right category “Hosting Support” and choose a descriptive title? The Hosting Support category is all about problems. And having two topics by the same person with exactly the same title but completely different issues makes things hard to keep track of.
As for your question itself, that’s a configuration that happens when using WordPress with Cloudflare. This article tells you how to fix this:
Install CloudFlare Flexible Plugin
I would not recommend that. It would be best to use Cloudflare normally, and set up SSL that way.
