mkh2006
1
epiz_30701133
why /?i=1 is visible with my website link when I visit the website, is there a solution for that, or how I can solve that step by step?
YT_Xaos
2
Please read this article.
KangJL
3
Since you did not provide sufficient info, my suggestion is to upgrade to premium hosting
There is a secret way to remove it, but I think it’s against the TOS.
You can just use Cloudflare. It works, and it’s not violating any rules.
Admin
6
You can just remove the suffix through your own code if you wish. We have no reason to stop you from doing that.
Just know that you do so at your own risk. If you end up breaking your site with it, that’s on you.
So if the Admin says it isn’t against the TOS - it can be removed with the .htaccess file. Just search in Google and you will find a solution.
system
Closed
8
