HTTPS Connection Timeout Despite SSL Certificate Being Installed
https://flicksy.kptmproject.online
My Let’s Encrypt SSL certificate has been successfully issued and installed, but the Live SSL Status still shows “Not Found”.
The website loads normally over HTTP, but HTTPS connections time out.
I have already confirmed that:
The domain resolves to 185.27.134.202.
The SSL certificate is installed.
HTTPS times out when tested using curl.
The issue also occurs on mobile data.
Could you please help me identify why HTTPS is not working despite the SSL certificate being installed?
Thank you.
HTTPS timing out while HTTP works isn’t something I can diagnose from here, and I couldn’t find a documented cause or fix for it.
A timeout is different from the errors the SSL install article describes. It says a missing certificate shows up as an SSL protocol error, and a certificate that hasn’t been picked up yet as a browser warning. Neither is a connection that never completes.
The article also says a new certificate can take a few minutes to take effect:
Your symptoms look a lot like two other recent topics, where HTTP on port 80 worked but port 443 timed out, also on mobile data. I can’t say they have the same cause as yours, and neither one has a posted fix I could point you to:
Your tests already point away from your own setup, because the timeout happens on a second network too. If port 443 on your hosting IP isn’t answering, that’s on the server side, and nothing in your account settings will change it. A person needs to look at this one.
Looks to be working for me now.
It can take a couple of hours for SSL certificates to install.
Are you still having the same problem?
