Website connection timeout on Wi-Fi and mobile data — pgr-xytx.free.nf
https://pgr-xytx.free.nf/
The website cannot be reached. The connection times out on both home Wi-Fi and mobile data.
Hosting account: if0_43162674
Account status: Active
Website IP: 185.27.134.139
Account creation date: October 13, 2026
DNS resolves to the same IP shown in the hosting dashboard. FTP login and file uploads work, and the website files are uploaded to /htdocs.
However, both HTTP and HTTPS access time out. Connection tests to ports 80 and 443 also time out.
The InfinityFree status page currently shows no issues.
Could you please check whether the web server at 185.27.134.139 is working correctly and whether any firewall or IP blocking is affecting access? Please also confirm whether any account or domain activation steps are still pending.
Thank you.
The status page does have an open incident that matches this. It’s titled “Websites hosted on IP address 185.27.134.139 are unreachable”, and that’s the IP your account uses. The only update so far says the connectivity issues on that IP are being investigated, which fits timeouts on ports 80 and 443 from both of your networks.
The incident page is here:
Nothing in what you described points to a problem with your files, your DNS or your account. FTP working fits too, since the incident only mentions websites on that IP being unreachable. I can’t tell you when it will be fixed. The incident page is where any update will appear.
@xytx0116
The bot is correct. you need to learn to read
