https://terabyte-techs.42web.io
.htaccess file disappeared from the root of said site when human error occured on my part whilst inputting blocked IP ranges(see image inline attached.
please advise and assist?
thanks, J
thanks, J
Likely due to this
I didn’t delete it or upload elsewhere KangJL. this isn’t my first rodeo with websites or hosting svces, i’ve been doing this kind of webdav for almost 3 decades but this in fact the first time i’ve seen .htaccess seemingly vanish from the root directory whilst using the cpanel to input blocks on for example, all of North Korea, all of Libya and since i’m no friend to a specific site in question, all of Facebook in cidr format. again what gives as now i see no blocks in IP blocker cpanel but can still reach the site fine. please advise?
thanks
Did you read the article I posted?
If not, please read.
The answer is right there.
okay that topic still didn’t answer my question or inquiry. this is what is missing from the root
I can see that you do not read.
Let me quote the answer for you.
Can you see the answer now?
I read fine, I missed the .htaccess size but thanks for clarifying it. appreciated
Welcome, I do admit that these articles can be quite lengthy sometimes…
okay so if I reload the .htaccess file with just the default content intact it should re-appear I’m going to guess??
If you do not exceed the 10kb size limit…
excellence. that worked, thanks KangJL ![]()
