This question is probably more for @Admin, I doubt that anyone will know it but if you know just post.
Hello,
How did you manage to edit, for example, the Tutorials link on vPanel and remove the Support Links?
There is no such customization on MOFH panel, and I would like if you could tell me how you did it.
Hello,
Creating IF clone and asking to admin of IF. Not Fair.
BTW it’s in customization section of MOFH panel.
@Ranakhas said:
Hello,
There is no such customization as I mentioned, and who told you that I am creating IF Clone?
@ChrisPAR said:
@Ranakhas said:
Hello,
There is bro is left side customization forum URL customization and Support system customization.
Creating OFH is makes sense that you are creating IF clone.
@Ranakhas said:
@ChrisPAR said:
@Ranakhas said:
Hello,
There is no such customization as I mentioned, and who told you that I am creating IF Clone?There is bro is left side customization forum URL customization and Support system customization.
I think @ChrisPAR means how did Admin change some links for example:
- The support ticketing integration system on VP has been deleted.
Exactly, any help would be appreciated, especially from @Admin
@Ranakhas said:There is bro is left side customization forum URL customization and Support system customization.
Of course not, what I do is having a MOFH hosting in Greek, for Greeks, and with a Greek KB and support.
Clones never actually succeed, so it would make no sense to create an IF clone.
Are you serious?
Are you creating client area or not?
@Ranakhas said:
Are you serious?
Yes
Not so sure, but I think I will start improving right away!
@ChrisPAR said:
@Ranakhas said:
Are you serious?
Yes
Mail me with URL and other information.
@Admin I need an answer.
Also, I need an answer on how did you manage to remove the Change Password Link and put a Client Area one instead in vistapanel. Please.
It’s not magic and it doesn’t require any special controls beyond what’s provided to all resellers. You’d not be the first to copy it from InfinityFree, but the first who can’t figure it out on his own and asks it here.
@Admin said:
Also, I need an answer on how did you manage to remove the Change Password Link and put a Client Area one instead in vistapanel. Please.It’s not magic and it doesn’t require any special controls beyond what’s provided to all resellers. You’d not be the first to copy it from InfinityFree, but the first who can’t figure it out on his own and asks it here.
Wait, I really mean it. I use MOFH Dashboard and there is no setting for changing the Tutorials link, disabling the Support System (there is only the option of changing its link) or disable the Change Password link and instead create a new one called “Client Area”.
If you really can’t say it (TOP SECRET!) I will have to go iFastnet. I did not want to waste their time but apparently you think that everybody has your knowledge and we can just simply do that.
I can give screenshot if you are not convinced. No other hosting has these features.
I know of at least two other free hosting brands using this platform who have either copied my code or built something very similar to what I have after learning what I did.
Also, note that I said that you can do it with the tools provided by the platform. That doesn’t mean that there is a section in the reseller panel specifically for editing control panel sections.
@Admin
iFastnet said me it isn’t possible to customize vPanel or access its content in any way.
I assume then that you may be using a premium reseller program? I am on the free.
You probably don’t want to share what you have learned for free, which I understand, or don’t want to share it at all.
I really am confused right now, you have also made some changes (force HTTPS on vPanel links) which was also not available from the Customize Section, and it is really good. After all, I am not someone who uses something without permission first, so that you know I wouldn’t copy your code.
I think the admin is aware that he (might) made a mistake
when on several occasions he announced that he was also the owner of (I will be silent)
I remember one moment, when one user wrote to admin (completely unaware of the situation) something like:
“you will see!!! when I report you to the owner, you will no longer be an admin”
if less people know that admin is (silence) it gives him a lot more room for manoeuvre and an additional layer of protection from any criticism addressed to (silence)
on the other side it is nice to see that the owner directly participates in…
ultimately, he would not have to deal with questions about mofh.
Of Grendel hosting?
Were was that? Admin is the owner.
You mean his identity?
on the other side it is nice to see that the owner directly participates in…ultimately, he would not have to deal with questions about mofh.
I didn’t quite get that.
@ChrisPAR said:
@Admin
No, I don’t have any special premium options which let me customize control panel stuff. Like I already said, it’s possible to change control panel links with the tools provided to all resellers.
Also, there is nothing to force HTTPS on the control panel. You can still connect to it without HTTPS, but all the links in the client area are HTTPS, so you are secured if you use the one click login from the client area.
@Admin said:
@ChrisPAR said:
@Admin
I really am confused right now, you have also made some changes (force HTTPS on vPanel links) which was also not available from the Customize Section, and it is really good. After all, I am not someone who uses something without permission first, so that you know I wouldn’t copy your code.No, I don’t have any special premium options which let me customize control panel stuff. Like I already said, it’s possible to change control panel links with the tools provided to all resellers.
I am new on this so I don’t know any tools except from MOFH panel tools, which BtW have nothing like this.
So, i must probably search. If I post it on the Byet Forums do you think that anyone would help me?
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin
I’ll.
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin
Are you seriously asking for permission on one free hosting provider forum to post a message on another free hosting company’s forum?
It’s a forum! There is a subforum about MOFH! The question should have been asked there, not here, to begin with!
