How did InfinityFree manage to customize vPanel links?
@Admin said:
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin
iFastnet said me it isn’t possible to customize vPanel or access its content in any way.
I assume then that you may be using a premium reseller program? I am on the free.
You probably don’t want to share what you have learned for free, which I understand, or don’t want to share it at all.
I really am confused right now, you have also made some changes (force HTTPS on vPanel links) which was also not available from the Customize Section, and it is really good. After all, I am not someone who uses something without permission first, so that you know I wouldn’t copy your code.
No, I don’t have any special premium options which let me customize control panel stuff. Like I already said, it’s possible to change control panel links with the tools provided to all resellers.
I am new on this so I don’t know any tools except from MOFH panel tools, which BtW have nothing like this.
So, i must probably search. If I post it on the Byet Forums do you think that anyone would help me?
Are you seriously asking for permission…?
Of course not, what I did is asked if you think anyone would help me.
It’s a forum! There is a subforum about MOFH! The question should have been asked there, not here, to begin with!
It was about InfinityFree, how you managed to customize links, not how to actually customize them!
I got my answer, topic ended.
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin
This forum is about InfinityFree, yes. But “InfinityFree” in that context means “the services provided by InfinityFree”, not “how to create your own website like InfinityFree”. If you need help using MyOwnFreeHost, you should ask that through the support channels of MyOwnFreeHost.
@Admin said:
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin
iFastnet Support Channels yes…
And also, I never asked how to create your own website like InfinityFree, just how to customize some links.
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin said:
@ChrisPAR said:
@Admin
Ergo, copying what I’m doing.
@Admin And it’s hard for you to say so for the stupid discussion to end ?!
Don’t worry, and sorry if the discussion drived you crazy.
I have found it, and all I can say is that it is in JavaScript format.
@Admin, may I use a part of your code just to customize the KB/ Tutorials link?
@Admin said:
It’s not magic and it doesn’t require any special controls beyond what’s provided to all resellers. You’d not be the first to copy it from InfinityFree, but the first who can’t figure it out on his own and asks it here.
You are right here, but instead of looking directly from vPanel source code and using it in ad code of MOFH, I prefered asking you. After all, its your code,!.
I did my research, and thank you for pointing this. I found the tool and even did some customizations myself.
I just don’t like copycats, and I definitely wouldn’t like to be one of them, using something else without permission. That is stealing.
