Help My Website is Offline, ERR_CONNECTION_TIMED_OUT
My Username is
epiz_32296726
poppybarktvsby.site
Yesterday my website is worked, now i want to update some codes but the website is down, the cpanel is working but the site is down, can you please help me.
Thank You
You need to check with your domain registrar
That is not true. More likely some domain registration issue
hello thanks for your reply, im using cloud flare name server on domain, how to add 2 more name server from infinityfree to domain setting
Do not do that. Never mix nameservers!!!
Just add in A record will do.
Follow this guide
Make sure to resolve domain registration issue in the first place
i’m sorry but i already did that before
the website before is working,
Did you
You domain is likely onhold by your registrar pending verification
Make sure A record is pointing to 185.27.134.102
al ready pointed to 185.27.134.102, wait maybe i need re add record
is it working if i delete my domain on domain addson and re add it again?
Keep doing that. It’s never going to work.
Unless you
No
i’m sorry i didn’t get it it the first place lol,
i already resend registar verification, and already verif it sir
do i need add record in domain registar sir? or is it enough in cloud flare?
What nameservers are you using now?
its from cloud flare
Just wait for dns propagation
thankyou for your guidance sir, i dont know why this happen, the site is working before tho
Looking good now
im so gratefull to you sir, im sorry if i made mistake hehe
thanks for the support and guidance, wish you happy life sir! :innocent:
