is this setting okay? how long does it take to activate webmail?
i changed from mx1/2.improvmx.com. i’m not sure if i did right.
why there is not abcd1234.epizy.com domain. i can see only my domain.
The mx.byetcluster.com and mx.epizy.com won’t do anything, as we don’t provide email services. You’ll need to delete them, as explained in the tutorial:
Perhaps the main domain is no longer displayed there? This is for the best, as it helps avoid confusion. If you go to the dropdown list of domains, do you only see yours?
Because you can only see and manage your domains ![]()
It didn’t always use to be this way. The tutorial (to which I linked above) mentions a record for the “abcd1234.epizy.com”-styled main domain which used to exist, but logging in to my account I can also no longer see it, which is good news!
