Warning: require_once(/home/vol4_4/infinityfree.com/if0_37471130/htdocs/wp-content/plugins/royal-elementor-addons/freemius/includes/class-freemius.php): Failed to open stream: No such file or directory in /home/vol4_4/infinityfree.com/if0_37471130/htdocs/wp-content/plugins/royal-elementor-addons/freemius/require.php on line 56
Hello, I’m opening a topic because I have a problem with elementor. I’ve done a migration via my old host’s files but I’m getting an error message, so I can’t access the admin area.
Windows has a different way to show file sizes; the file size limit for HTML/PHP files is 1 MB, which is equal to 1000 kB, which, converted in kiB (Windows uses bibytes and shows them as if they were bytes) should be 952 kiB, so your file is over that limit by 37 kiBs! You should consider splitting it up whenever it’s possible to do so and put the rest on a second file, obviously with start and end tags even on the second file, and include/require the second file in the first one.
