parafiakorytkow.rf.gd
Your InfinityFree account if0_36360547 (Website for parafiakorytkow.rf.gd) has been temporarily suspended.
Your account was suspended because you hit the Entry Process limits.
This has been happening for 6 days now, over half a year ago there was no such problem. HOW TO FIX THIS?
Thank you
Could you please explain to me in simple terms how I could fix this. I will add that it has been hanging for 6 days now, and I can’t even access any settings, only for a few hours
Mam mało doświadczenia, czy są jakieś artykuły jak wykonać te dwa punkty?
I have little experience, are there any articles on how to perform these two points?
I’m not quite sure what you need help with as both points are very straightforward.
If you have non-PHP files using the .php extension, change it to the extension of the file (Like .html)
And if you use AJAX on your website, reduce or remove it
