DNS zone for silvana-schiller.de not active
silvana-schiller.de
In Browser DNS_PROBE_FINISHED_NXDOMAIN
http://silvana-schiller.de/wp-admin/ and silvana-schiller.d
Hello, my domain silvana-schiller.d was successfully verified via CNAME. The WordPress files are fully located in the directory /htdocs. However, the website is not accessible, and even /wp-admin does not work. Please check if the DNS zone has been correctly created and is active.
Thank you!
Hi and welcome to the forum! After adding your domain to your hosting account successfully, you’ll have to follow this guide if you still want to keep using your own nameservers:
Or you can simply change the nameservers for your domain to ours by following this guide instead, since the DNS zone is already active:
Only adding your domain to your hosting account isn’t enough for your website to work.
Hello,
thank you for the explanation. However, I believe my case is different: I’m using a .de domain (silvana-schiller.de), and while the CNAME verification was successful, the domain is still not resolving.
I’ve already:
• Added the domain to my InfinityFree account
• Verified ownership via CNAME
• Uploaded all WordPress files to silvana-schiller.de/htdocs
• Waited over 48 hours
But DNS propagation is stuck – only a few servers show the IP 185.27.134.151, and the site is not accessible.
I suspect the DNS zone was not properly created for this .de domain.
Can you please check if the DNS zone is active and complete?
Thank you!
Remember that DNS propergation can take up to 72 hours
CNAME verification, as you can see, is only verification. It doesn’t make your website actually works.
Hello and welcome to the community. Are you sure you did not miss any step in the articles pointed above? I’ve checked and the domain is quite very new. And if my time is correct the domain is not even a day old by the time you started this thread. However, you mentioned you already waited more than 48 hours. I still see nameservers related to IONOS/1und1. Kindly check if you made the necessary changes in your registrar. It might help.
